Failed to record audio chunk
I have been using 6 Amcrest Pro HD 1080 IP2M -866EW for about a year with out any problems. All of a sudden I am seeing random failures in 2 of the 6.
There was an error while recording audio data for camera "East Sun Room". Failed to record audio chunk. 5.5.6,7560,50888
The server shows no pressure and hasn't change .... Any idea where to look.
Dale
  • Hi Dale, you are running the previous v5.5.6 release - I believe if you update to the latest v5.5.7 release this problem will go away. Use the "Check For Update" option in the SecuritySpy menu to update, and then please confirm whether this resolves the problem for you.
  • Sorry I did not get this earlier - Yes it did go away
  • Great to hear that.
This discussion has been closed.
