Does SecuritySpy support using the Axis M1065-LW PIR sensor for triggers?
I have a few of these cameras and love them, but for some reason the PIR option is disabled in SecuritySpy > Preferences > (camera) > Triggers for each of them.
I am using the "Axis" profile in Preferences > (camera) > Device, and a view-only username and password, if that matters.
I would really love to use the camera's built-in PIR for motion detection if possible!
Do I need to configure these cameras differently?
Unfortunately this is currently not supported. SecuritySpy can get camera events from Axis cameras to detect inputs from the IO ports, but the PIR works in a different, much more complex way, and so few Axis cameras have built-in PIR that it hasn't been a priority for us to implement support.
I believe the camera may have the ability to invoke a URL when the PIR is triggered - if so then this can be used to trigger SecuritySpy (via the "triggermd" request described on the SecuritySpy Web Server Specification page).
Alternatively, SecuritySpy supports triggering from HomeKit devices, so a HomeKit-compatible PIR sensor can provide the functionality you need. -
Okay.
I have used AXIS PIR URL actions before, and just set up an event to send a notification to the "triggermd" request instead. Looks like this may do the trick.
Thanks!
