Motion captures not being saved to internal HD
mbernhardt
edited June 2021 in SecuritySpy
Mac running 11.2.3 and SecuritySpy 5.3.3. Somewhere along the way in the last several months, motion capture files that I was saving to my internal drive stopped saving. But if I change the location to an external drive, it works. I tried giving SecuritySpy "Full disk Access" but it didn't help so I'm removing that again. Any ideas?
  • I figured out the problem. "Delete old files by available space" was set to 50gb, but there is only 48 gb available. So it never saves them. I dropped the number to 40gb and it worked. A suggestion: perhaps put a warning next to that option when the available space is less than what has been entered?
  • Great to hear you figured out the problem. In the next update, we will be adding a warning message (that goes to the log and gets emailed if you have this option enabled under Preferences > General) that detects and reports this situation.
