Audio way out of sync from video
Brady1
edited December 2020 in SecuritySpy
I'm running SecuritySpy on an M1 Mac mini, and observing using the iOS app.
We've tried two different brand cameras monitoring our kid playing in another room. With each one the audio gets (very) out of sync from the video.
The video stream is "real-time-ish", but the audio is ~1sec behind.
What can I do to help diagnose/fix this?
Thanks!
  • Does this happen only while viewing via the iOS app? What if you listen to the audio via SecuritySpy itself (click the speaker icon in the Camera Info window to hear the audio there). Also, does the audio stay consistently 1s behind, or does it progressively go out of sync?
    For such live streams, some amount of offset between audio and video is to be expected - both are being delivered and presented as fast as possible, and audio needs a longer buffering time to avoid playback problems. 1s is towards the upper end of what should be expected, but it's not excessive (as long as it doesn't progressively get worse beyond this of course).
