Trigger other cameras isn't working
barefootguru
edited June 2019 in SecuritySpy
I've set one camera (Cam1) to trigger another camera (Cam2) which covers some of the same area. Cam1 is recording footage correctly when there's movement, but there's no recordings from Cam2 at that time. I was anticipating SecuritySpy would trigger a Motion Capture event for Cam2?
  • As far as I know there is no bug related to this functionality, and I have just tested this here to make sure, and can't find any problems.
    The first thing to check is that the schedules are set correctly. For Cam1 to trigger motion-capture recording on Cam2, then Cam1's Actions mode must be armed (e.g. its Actions schedule set to "Armed 24/7" or some other schedule that arms the camera), and Cam2's Motion Capture mode must be armed.
    Does this fix it?
  • That's what I've got, thanks. I'll send some screenshots in.
