Amcrest & Current Beta
sproctor61
edited July 2017 in SecuritySpy
Hi Ben,
Just installed the current beta to see how it works. Part of my cam setup is my Amcrest 4 cam DVR. All has been working well on the released version, but in the current beta, the cams seem to randomly switch to different video. For example, the video for cam 1 changes to cam 4 then back to 1, etc etc. Just wanted to give you a heads up.
  • This is very strange, it sounds like it could be something to do with the video display to the screen for some reason. Are you using the "All Cameras" window or a Group window? If you are using a group window, is this set to cycle through cameras periodically, or is it set to display all cameras at the same time?
