After upgrading to 4.1.5, now capturing to Home, not 'Capture Destination' of camera
jlbrown
edited June 2017 in SecuritySpy
After upgrading to 4.1.5, Security Spy is now recording to ~/SecuritySpy/Captured Files but the cameras all have my external storage for 'Capture destination' in Setup pane.
James
  • Hi James,
    I have tested this and can't reproduce this issue. The main reason why this could happen is if SecuritySpy can't find your external drive. Could you please double-check that your external drive is correctly mounted on your Mac, and that SecuritySpy is correctly configured to capture to it? Try resetting the capture destination and setting it up again (under Preferences -> Cameras -> Setup).
  • Thanks Ben.
    The external storage was mounted.
    I quit SecuritySpy, emptied the Captured Files folder then restarted SecuritySpy. All seems fine now. The folder remains empty.
