Camera Info Window; Loss Field
This value is updated every 10 seconds, and is the percentage of lost data packets over this 10-second period. With a good-quality camera on a fast network, this should always be zero. If it's frequently above zero, then check the network (e.g. WiFi reception), update the camera's firmware, and/or reduce the camera's frame rate.
Thank you.
