Active Silicon LFG4-MM-PE1 not working with SS4 - need help
The driver software for this card is 32-bit, so therefore you will need to use the 32-bit version of SecuritySpy (instead of the 64-bit version, which is the default one). You will find this in the downloaded SecuritySpy disk image, in a folder called "32-bit version".
