error-22185-8969 on 4.0.10 with Reolink-426 cameras
Just got 2 Reolink-426 cams, having frequent error-22185-8969, lowered cam encoder to H.264 Baseline Profile, 2560*1440/10fps/max bitrate 6144. streams are good & stable in Reolink client software but Security Spy feed keeps going blank for these two cams for short periods then re-establishes . I have plenty of bandwidth & CPU, doesn't seem to be resource related. Please advise.
selecting from General Configuration tab,..."Decompress incoming video frames only when needed" seems to solve the issue.
Good to hear that. The new beta version (4.0.11b8) may also help, so if you are able to try this please report back.
My two reolink-423 cameras drop & won't connect with that beta build 4.0.11b8
Ben, found that one needs to use "Auto discover devices" again for ONIVF devices after launching the Beta 4.0.11b8. PS: also PTZ presets work now also THX BEN!
Odd, sometimes RL423 cameras using ONVIF will come "on-line" after waiting about 1 to 2 minutes, However if I launch the ReoLink client software and select "Play" in ReoLink then SS joins streams immediately.
PS: occasionally getting the error on beta version...Error from camera, it will be closed. (Failed to decompress incoming video frame 22185,-8969 Image data decompression failed - bad data) will not re-open until I launch the ReoLink client software and select "Play" in ReoLink then SS joins streams immediately. -
Running 4.0.11b10 burning in for 4 hours so far ...working flawlessly so far.
Two days Running Beta 4.0.11b10 ...working flawlessly so far.
