Help ! Samsung DVR SHR 616
Hi, most likely you're going to be out of luck here. DVR devices tend to be closed boxes that aren't designed to work with third-party software. In fact I'm struggling to find out much information at all about the particular device you mention at all.
Any device that can send video as an HTTP JPEG stream, a MPEG-4 RTSP stream, or a H.264 RTSP stream, will work with SecuritySpy, so if you can find out this information from the user manual or the manufacturer then you may be able to get it working, however my internet searches thus far have not turned up anything useful.
