Feature request: camera info shows when AI is capturing
  • Just installed the new SS with AI recognition. The old Camera Info window would indicate when motion capture was being recorded — the Motion bar would flicker red. With the new SS that just means motion is being passed to the AI, so you can't tell if anything is actually being recorded? Would be good if there was again a way to see if anything was being saved to disk.
  • In the new version, it's true that the red bar indicates pixel-based motion detection, so, as you say, this determines which images are passed to the AI.
    However, you can still tell if an actual recording has been triggered, because the red "M" symbol turns red in this case. If the "M" symbol stays grey, this means that no recording has been created.
  • Perfect, thanks!
