Options for PC Screen Capture
  • Are there any options other than AbelCam for PC screen capture to SecuritySpy? Thanks
  • Hi - I don't know of other specific options, although there must be some. The software would need to send the video over the network as a standard MJPEG stream over HTTP, or alternatively in any format over RTSP. Is there any reason you don't want to use AbelCam?
