Foscam 8910 Audio
I have a Foscam 8608, Foscam 8910 and a Panasonic BL series Network cameras. I've downloaded the trial of Security Spy and really like it so far but I've found that even though my Foscam 8910 is supported and has audio, I can't get Security Spy to recognize that it has audio which makes kind of a problem as I need the cams to record audio as my neighbor is complaining of my dogs barking. I need the audio proof one way or the other
Is there a way to get the audio working on the Foscam 8910? The only driver option is Foscam JPEG pan/tilt which doesn't allow me to select audio
The audio works on my Foscam 8608 and my Panasonic BL series camera.
Please help
Please help
I need to add a couple more cameras that have audio, neighbor is complaining about my dog barking and I need the audio. Can I have multiple rtsp Foscam cameras like the 9821W? Right now my Foscam 8608 is on port 80 not sure if I add another rtsp cam if I can set it to another port like 81?
I saw another post about the 9821 needing to be on its default port of 88. If I get 2 of them will I be able to get them both to work with Security spy?
Thanks for your help and the awesome software!
We've temporarily removed the FI9821W from our list as some users have reported issues with the camera requiring frequent restarts. Foscam have just released new firmware which we are in the process of testing so we'll know soon whether these issues are fixed. In the mean time you may prefer to go for a different camera - there are loads of options on our supported camera list.
So far I've only hooked up one and have it hard wired as the wireless was next to useless. Even on wired the camera will occasionally lockup.
Since there's no daily reboot option like on my Panasonic camera I set a power timer on it to cycle the power every day. This has made it a little more reliable but I still have an occasional lockup
I'm running the latest firmware .13
