No audio on MicroSeven movies
  • I believe all items are correctly set. I can hear the audio when viewing live.
    But the movies do not contain audio.
    Audio Device: 'This network device'
    record audio with continuous-capture movies
    Any thoughts/suggestions greatly appreciated.
  • It sounds like you have all the correct settings.
    Are you using the latest version of SecuritySpy?
    Check the log file (File menu in SecuritySpy -> Open Log) to see if there are any error messages related to this.
    If this doesn't help, then please contact us by email at support@bensoftware.com and we will help you directly.
  • I upgraded to 4.2.9 from 4.2.3 and found no difference.
    nothing shows in the log pertaining I dont believe.
    I have sent an email with screen shots of my settings and log.
