No Cameras
  • OK, so just upgraded and installed the app - I can see the cameras with the "Cameras" tab
    But then I select "Captures" I get "No Cameras".
    There are some recent .m4v files in the ~/SecuritySpy/Captured Files directory - is there something else that needs to be switched on?
  • I found the solution - a bit basic, really, that the permissions for the user were just to view live footage. It would have been nice if the app had been able to determine that and tell me. One of those things that, once you know it, seems obvious.
